superj
Well-known member
and no vacuum leaks right?
do you only have two mixture screws? sometimes four barrel carbs have four mixture screws. also, when you floor it from a stop (or anytime) does it kind of bog or stumble for a second and then pick up? from a stop does it almost die when you just floor it?
it kind of sounds like you have an accelerator pump issue also. pop the air cleaner off and look in the throat with the choke plates held open and pull the throttle arm to see if the two squirts of gas are squirting. if they are not, your accelerator pump is not working which will give you the dieing when try and speed up issue or take off from a stop
also, is your carb a vacuum secondary carb? since its mainly doing it from half gas and onwards, it could be your secondaries are not opening or opening to fast. you could have to large of jets on the secondaries also.
