95 AT Jeep YJ 4.0 She ran great until September when gas started leaking out of one of the hoses under the drivers side rear. I drove it 2 more short trips until it really started coming out. It eventually stalled and I decided since that hose was apparently rotten and I needed to drop the tank anyway that I would go ahead and change the fuel pump, sending unit, rubber hoses, and fuel filter and those little hoses. I also installed a new tire carrier bumper since the fuel tank was out. Ive been working on this thing solo now in my spare time since Sept. 17 and yet to get her back on the road.
From what I can tell, I have the hoses hooked back up (I think properly), I couldn't squeeze that rubber grommet back in under the underbody so I used a plastic hose/wire protector. I tried to fire her up and it just spins.
Verified that the Battery is good, I hear the pump come on, there is fuel in the rail. I put in 5 gallons of fuel and it registers on the gauge, even though I don't have the tank fully bolted back in (I was attempting to test it). I swapped the relays out and they seem good as do the fuses. I do not see any movement on the tackometer when I try to start it (not sure if im supposed to). I also sprayed some starter fluid down the intake with no luck. The check engine lights seem to operate as normal.
I think I may have an underlying ground issue somewhere as the heater blower fan is not working either. It went out when I first bought it but since it was summer I didn't really worry with it. That's next after I get this girl rolling again.
Uncertain where I go from here...Thanks in advance for all the advise and direction I surely need it
