PRBLMATIC97
[FONT="]Swapped the led taillights the PO has installed with oem taillights and led fixtures because the lights that were previously on the Jeep had dead leds and were starting to go one by one. So after my install I tested to see if all the functions work and they all work except for my left turn signal. Every time I put my left indicator on the relay Bugs out and clicks many times but the turn signal does not flash.
Headlights on.. rear brake lights turn on and do not turn off and I have no turn signals in the rear
Headlights off.. Brake lights work when brakes are applied but when turn signals are on the hazzards blink in the rear
I cleaned my grounds and I checked my fuses
[/FONT]https://drive.google.com/file/d/1bE4u9KVeAVeqpnPDvMSqk1DJNQxTmlcL/view?usp=drivesdk
[FONT="]
https://drive.google.com/file/d/1Q1BUet_je-uEiR0Se7iXDmwxCuFeK-ZM[/FONT][FONT="]
NEED HELP!!
97 TJ 4.0L[/FONT]
[FONT="]
NEED HELP!!
97 TJ 4.0L[/FONT]
