00 Jeep Grand Cherokee Laredo no start after heater core R&R
Hello all
I like the first say thank you for all the helpful information in these forms. I'm having a similar problem with my 2000 Jeep Grand Cherokee Laredo. We recently changed the heater core and after putting everything back together it won't start. I've checked all the connections we removed during – removal and they're all good. Checked all the fuses and swapped some relays around. They're all good as well. I noticed that two wires orange and white with red trace were pulled out of the white connector on the solenoid on BTSI I have reattached these cables but noticed that they don't have power. When the key is on if the key is in the farthest position back I cannot shift. But if I roll it over once I'm able to shift when I touch the brake the solenoid doesn't click if I apply power to the orange cable, the dash lights come on. Side note I have hazard lights, horn, high beams, headlights, and break lights. Turn signals do not work but hazards do wipers do not work. I'm assuming that the key is not working correctly and not turning everything on. I've tried to change the tumbler out but it did the same thing. If I could get any help that would be greatly appreciated and thank you in advance.
