Micah Chambers
Ok I have the same 97 4.0 auto trany TJ P.O.S. I have been dealing with for 7mo. now! I have put a new timing chain on it and it is acting like its not timed right. It will not crank only act like it will then backfire through throttle body. When I installed the chain I removed the cover and valve cover and distributor. when I installed it I made sure the cam pin was at 1 oclock and the #1 cylinder valves were closed and I was at top dead center on #1 cylinder. I then installed new chain with dots lining up perfectly and reinstalled distributor and the button is pointing to #1. I have double and triple checked all my wires and the covers off now and everything is lining up where it should according to manual's WHY THE F ISN'T IT STARTING!!!!!!!!!!!!:x:x:x:x:x and why is it sounding like its out of time??? I have taken down and rechecked every thing lines up perfect!! Can any one PLEASE help me. Oh I also have new PCM crank sensor cam sensor plugs wires and cap and button. And all wires are hooked up on cap from front to back 153624. Oh and earlier today had it hooked up to the new snap on computer and it showed it to be 68 degrees off time and that the TPS was bad.The cam gear was 180 out from my crank.
