Ford 8.8 rear axle
At this point I decided to try my first big boy mod.  I dropped in a 1997 Ford 8.8 rear axle.  This is quite a bit beefier than the stock Dana 35, and would be a good basis to build on.  I rebuild the limited slip in the Ford axle and decided to run that for a while until I can afford a select-able locker.
Limited slip with 3.73 gears (matched my Jeep)
As it looked when I took it home:
The S spring is what applies tension to the clutch packes (one on each side of the spring).  This is the LSD (limited slip differential).
It took more work than expected to clean this thing up - that and about 10 cutting wheels.
Welded up and ready to install
A new solid brand diff cover and some RTV.  The stock diff cover is paper thin.
These are parking brake cables from a Jeep ZJ.  They mate up perfectly to the Ford 8.8
Axle installed in the Jeep
Here you can see the Spicer yoke adapter that allows my Jeep driveshaft to adapt to the Ford 8.8.
Costs:
Ford 8.8 Axle
limited slip and 3.73 gears = $175
Diff Cover
Solid differential cover = $65
Gear Oil
Mobil 1 75-140 Synthetic = $19.99 x 3
Friction Modifier (for the LSD)
Summit Racing $5.95
Ford Racing Friction Modifier M-19546-A1 - SummitRacing.com
Bracket kit from Mad4wd.com
1 x TJ Wrangler Rear Axle Bracket Kit (Axle Kit-TJ)  = $199.00 + shipping
TJ Wrangler Rear Axle Bracket Kit [Axle Kit-TJ] - $199.00 : Mad 4 Wheel Drive
Total: $216.11
Yoke adapter
Dana Spicer Ford 8.8 Flange Yoke Adapter 1310 U-Joint = $25.99 + shipping
Total    $31.64
Yoke bolts - 12mm x 1.75 thread 12 point.  Ford PN: N800594-S100.
Brakes
Advance Auto Parts
Wearever Silver Brake Pads MKD667 - 35.33
Wearever Silber Brake Shoes NB701 - 23.99
Wearever Brake Rotors YH145052 78.73
(i paid 126.27 for all brake parts)
Currie Disc Brake Hose Kit - $36.95 + shipping
Currie Enterprises Racing Rear End Categories
Total - $46.36
Labor:
Weld on Brackets = $200
Grand Total - 926.30   :shock:
