Aluminum is lighter than steel. Steel is more resilient from blemishes, the outer rim can be bent back if you hit a rock hard enough to break the tire off the bead as aluminum is likely to crack. Steel tends to rust if not properly cared for. Aluminum can tarnish as well if not cared for. Mmmm, i picked steel. More durable IMO.
