No brake lights, help!
Ok guys a buddy told me the other day as I left his house that my brake lights aren't working, sure enough, tail lights, turn signals, hazards, all working, but no brake lights. I checked all my fuses and they're all good, is there a brake light relay or something or could it be the sensor on the top of the brake pedal?
I would check the connections on the brake lamp switch first. Have someone monitor the lamps in the back while you actuate the switch manually. Check the circuits for 12v and grounds.
Replaced the switch and it still didn't work, come to find out I had no power going into the switch so I fixed that and it works perfect now lol thanks though man!
