Door Removal
Jeeppicus
No, this ins't the normal how do I take my doors off question. I was hoping someone here knew how to take the door panels off a half-doored TJ. I tried all the little Torx bolts and it still wouldn't come off. Thanks for the help in advance.
RE: Re: RE: Re: RE: Wont start unless i hit the gas....
It's likely held in with plastic clips. Carefully pry the panel away and look behind the panel, you'll see where the clips go into the door. Pry on both sides of a clip to get it to come out, they even make a special tool for this.
