riotsnclowns
Hey guys!
A few quick questions.
I bought an 06 TJ with a four inch lift. The kid did cross between a budget booster and coil lift. I put in a T-Case drop and have noticed a whining noise from the rear end, when driving, which one could only assume to be my rear diff. Will an SYE correct this noise? Also once I get the SYE and put it in what else should I do at the same time? Any recommendations.
My other issue is that this is a 6 speed manual. When driving, down hill 5th gear 3500 rpm, and shift into 6th gear my rpms fall and so does my speed. What could cause this? Has any one come across a similar issue?
Thanks for the help and input in advance!
