I rebuilt the front driveshaft about 8000 miles ago using all spicer parts. I've now got a nice little squeak. Spraying WD40 on it stops the squeak short term. Is this a failed ujoint or something else?
I rebuilt the front driveshaft about 8000 miles ago using all spicer parts. I've now got a nice little squeak. Spraying WD40 on it stops the squeak short term. Is this a failed ujoint or something else? Video Link: https://youtu.be/fUp5jk1ihvg
Sounds like it. Did you use anything other than Spicer grease? They have a special grease that will not erode their joints.
Any movement in the joints
If you could just spray with penetrating oil and the noise goes away the seals are leaking or damaged. You will likely find dry bearings.
A squeak is likely the centering ball in the double cardan joint. The ujoints are fine if you just replaced them. It will require dis-assembly to properly grease the centering ball. Left unserviced the double cardan joint will grenade and take out the transfer case.
I couldn't see if your centering cap or unjointed had grease fittings.
You should always grease the ujoints during install, as well as the centering ball. The stuff used during manufacturing and shipping isn't adequate.
I've never seen a ujoint like this, but it looks exactly like what I need (with the grease fitting on the cup):
Amazon.com: Spicer 5-1310-1X U-Joint Kit: Automotive
Have you ever used one like this?
