superj
Well-known member
ok, after going through all the wiring on the 87 wrangler i just got (4.0 with auto transmission), when the carb was swapped, a nutter by-pass was not done. some other type of by-pass was done with a jumper wire in a plug on the engine side of hte harness. i did the nutter by-pass and it helped on the smoothness of how the engine runs but i cannot figure out why the jumper is there. i do know that if i pull hte jumper wire then the jeep dies. all the wiring harnesses in the jeep look unmolested except at the coil and i have unplugged all the sensors (they are all still present and plugged in) with no changes to how the gauges read. the only one that works properly is the volt meter. the fuel gauge and oil pressure immediately peg out when you turn the key to run and the temp gauge works for the first quarter of its range. the fuel gauge will randomly flop around after it pegs out sometimes.
can someone take a pic of how the engine wiring harness should look after a nutter by-pass and tell me what needs to be plugged where? also, i imagine i no longer need the 02 sensor, any of hte sensors in the intake, nor the odd valve stuck out from the driver's side of the intake with a vacuum line attached to it, seems like some type of emissions valve?
the jeep runs great and gets the same gas mileage as the wife's 93 wrangler with 4.0 and auto but i would like to know how everything is doing while i am driving around, is why i am asking all the questions
