campingnut1973
RE: Body work
I rotate my tires every 3000 miles when I do an oil change.....I put a 2" lift with sway bar disconnects on and the left tire has uneven tire wear to where u can take your hand and rub it and feel as well as see the uneven wear, but the right tire has even wear, and when between 47-50 m.p.h, my steering wheel shakes, sometimes it gets really bad when I hit a bump in the road and it feels like the steering wheel is coming off...is it my alignment or just bad tires....could the lift with sway bars, be the reason, I am just starting the process of figuring out what the heck is going on with my rubicon. This just started after I had the sway bars put on and I only went off road a few times, nothing too serious....any suggestions.
