Hi,
The following has been an issue for some time now on my Cherokee, and I'm now bumping it up in priority on my To-Do list as it is bugging me:
The front sway bar linkage on the passenger side of my Jeep rubs up against the coil spring. This means that often if I hit a bump I can hear the link clunking against the spring. What is so odd though is that the driver's side link and coil spring have like 2" of clearance between them. :?
I believe the bar began hitting the spring after I installed Rusty's 3" lift kit on my Cherokee, but am unsure as I never paid much attention to the sway bar before taking the Jeep apart. I was told that a possible way to fix the problem is to install spacer blocks between the sway bar mounts and the body of the Jeep. So I tried installing some home-made 1" blocks. They changed the geometry of the sway bar some, but didn't prevent the link from hitting the spring on that one side.
Has anyone run into this problem before? Oh, and I have pics if anyone needs to visualize the problem :mrgreen:
Thanks,
-Nick :!:
Thanks,
-Nick :!:
