Yep another lift question
Wow, it was so much easier when I connected my back up lights. I simply spliced into the exising back up light wires, and ground it on my frame, and that was it. Me lights come on when I put my Jeep in reverse. Since you want to add a (1)On/(2)off/(3)on when in reverse switch, all you have to do is find yourself a switch that allows you to "input" three types of power sources. That is a (1)constant or on when Jeep is on, (2) nothing at all (NO GROUND NEEDED) , and (3) power from the reverse light wires . I decided to go with two back up lights, so I connected (spliced) the left aux into the left OEM back uplight, and the right aux into the OEM back up light. This should work, in my opinion. Let me know if there is anything wrong with this setup because I don't want anybody to mess their electrical system up. My setup has worked for me (without a switch),and I figured that adding a switch would not be that big of a deal. -al
