Ok,I'm freaking out. I had a whining noise and then found my power steering fluid had completely leaked out at the connection of the high pressure cooling hose and the power steering pump. Now I just found an article saying the it can cause severe engine and coolage fan damage. http://www.billhughes.com/temp/WJfan.pdf
I don't understand how this can happen.
I'm going to remove the connection and see if there is an o-ring to replace if that is why it is leaking,fill it and see if it helps. I have a bad feeling that whining is very bad news. Any ideas? What kind of engine damage could this cause? 4.7 V8 cherokee :shock::?:
:shock::?:
 :shock::?:
:shock::?:
