Wrangl3r93
My jeep is undergoing a new wave of mods before I have to call it quits for a while once the baby comes. I've run it with the stock driveshaft on 4.5 inches of suspension lift for 3 years and it doesn't ride horrible but it's been getting worse and worse. Crawled under to take a peek and the degree shims that came with the RE lift have completely worn out and are allowing the axle to shift inside the ubolts. I'm ordering a SYE next weekend and already have the front xj shaft to shorten but finding an acceptable 8.8 rear end has been somewhat of a challenge. I plan to go ahead and put the SYE/driveshaft in with the d35 because all of my research says you can use the same driveshaft with the 8.8 so I won't have to do it twice. I'm trying not to throw money into the 35 since I know I am swapping axles anyways but I'm having trouble finding shims to set my pinion angle directly at the transfer case. It would have to rotate back quite a bit. Any ideas?
