Cool Ridge Jeep
Hello! I'm new to this forum but was hoping I could get your help. I have a 2005 Grand Cherokee Laredo, 4.7 L, Quadra Track II Full time 4WD. I'm getting it prepared for a cross country trip. One of the last things I decided to do in my maintenance was drain and replace the antifreeze. I didn't flush the whole system. I just opened the radiator drain plug and let drain out what would come out...which ended up being a gallon or so fluid. Then I closed it off and put new Dextron (pinkish red type) antifreeze back in. I filled the radiator until it was within 1" of the cap, then ran the engine for a few minute to circulate the fluid and then added more to bring the radiator full and added fluid to the overflow tank. I took off down the road and it started showing hot on the temp gauge within a few miles. I pulled over and let it idle and turned my cain heat on full and directed it to the floor to help vent the heat. I noticed that the air blowing on the floor wasn't particularly hot. I drove it back home and it still heated up to "H" on the gauge and told me to check my gauge. The upper radiator hose was very hot and the cooling fan was blowing constantly. Any ideas? I've never had overheating problems until I drained and refilled the radiator today. Sorry so long of a story.
