YuriSouder
So guys I fixed my back tire... you wont believe what I found. The guy I bought the jeep made this GETTO assembly. The centering pin just kept the leif spring together and did not go into the spacer in-between the axle and the leif spring. ON the spacer there was a notch to keep it on the axle. So I drilled a hole in the spacer(dont know the name) and put a centering pin in how it is supposed to be. By well is straight but the hole axle is still a bit forward, not a big deal. Looks like you guys were right, well kinda thanks alot for your help
