Need Help! Changing out Header Panel on 93 Grand Cherokee
Fellows
Hi, I am changing out the header panel on my 93 Grand Cherokee and need help and information on how to remove and reinstall the headlight adjusting gears. I purchased an after market header panel and have been able to remove the supports for the headlight but can't figure out how to take out and reinstall the headlight adjustment assembly.
Does anyone have information on how this is done?
Thanks,
Neil
By the way this is the best forum I have found for Jeeps. Keep it up!
REMOVAL
  1. Grasp lower edge of headlamp lens and pull straight back (away) from grille opening reinforcement (GOR) Disengage lower adjuster pivots from lens assembly.
  2. Grasp upper edge of headlamp lens. Pull straight back (away) from grille opening reinforcement (GOR) Disengage upper adjuster pivot from lens assembly.
  3. Rotate bulb lock ring counterclockwise. and remove ring and bulb from lens.
INSTALLATION
  1. Replace by seating the assembly in the lamp housing and turning the lock ring 1/8 turn clockwise to secure.
  2. Align upper adjust pivot into headlamp opening and snap into place.
  3. Snap lower adjuster pivots into place.
