bigTlilODD
Here's my intake. This first pic is all the parts in, without the filter attached. I used a 2" pvc coupler, which was FORCED into a 3" pvc drain. The drain had the little cross section guard on it, but that was easily removed with a dremel. The coupler was too big for the drain so I had to shave out just a little bit of the inside of the drain. Then I used a rubber mallet to join them together. They are not coming apart. The metal bracket I picked up in the vent section of Lowes. Where the roof vents and stuff are. I used self tapping screws to join it to where the old intake box was.
This is the whole thing together. Joopin\' Is this the part that you said was not on the filter?
