jay79cj7
FOLLOW UP: Rust Removal DONE!  (Pics/Story inside)
79 CJ-7 w/ stock power brakes
My master cylinder was leaking into my booster and loosing fluid pretty fast (front reservoir was dry one time) last fall so when I did the CJ rebuild and had everything apart anyway, I replaced it with a remanufactured one. They did not supply a gasket for between the master and booster, so I reused the old. It looks to just keep stuff out, rather than be a seal for brake fluid anyway.
The brakes work great, but its leaking again. I have a slow drip at the base of the cylinder where it bolts to the booster, and the fluid is disappearing again, I presume into the booster. There are no leaks that I can find anywhere else.
The gasket at the base is not in perfect shape, but that should not cause a leak, right? The master cylinder should not leak through the piston area to even get to this gasket, correct?
I believe that I need to replace this master under warranty, and I can't find a new gasket for the base anywhere for when I do. Is it important, and if so, where can I get one?
Should I steer clear of reman's and buy a new (more $) one?
Thanks!
Thanks!
