leaks on a 2000 tj
MRJMF
i have 3 leaks in my jeep two are from behind the dash (really heavy on the passenger side) and one location is unknown but the puddle is right underneath the handle to move the seat back, back and forth on the passenger side any ideas? anyone else have this prob?[addsig]
1065964
when my master cyl went bezerk it leaked into the floorboard inside, and pealed the paint off... :-O :-O [addsig]
1065976
you do have the floor plugs in right? mayhap that might be it, my pop's had a 94 YJ that poured water in every time he pushed in the clutch. we still never figured out what that was. i'd check for holes or gaps in the firewall. check all the weather sealing around the windshield and stuff like that.[addsig]
1065979
Jeeps leak! Check into your windshield gasket deal where it folds down and the intake grill over the crowl. Check your fire wall area for posible leaks. One good way to do this is to cover the cab with dark colored blankets and open the hood on a sunny day. Get inside and look for light cominginto the cab in the areas you think the leak is. Car wash is a good way to look for leaks too. Good luck and if you can not find the leaks just hurculiner the floors and remove a plug or two. Tug[addsig]
