Just learning need help
I just bought a 1976 Jeep Cherokee chief off of a guy and he had taken the front drive shaft out. When I go to put it back on which side of the driveshaft connects to the transfer case?
I believe on that one the Spline joint goes towards the transfer case.:scratch:
Don't know for sure on that exact rig...but they should only match up one way. Do both ends look exactly the same??
Sounds like you may be describing the CV joint. Does the big knuckle looking piece have 2 ujoints and there's one ujoint at the opposite end? If so, the CV joint attaches to the transfer case.
