jugghead23
First off, thanks to everyone who helped me before I purchased.
I have a number of questions and I'm sure some, if not all, of these have been answered before so please, let me apologize in advance.
There are little issues I found (all I could find) that I intend on fixing asap.
1. When I turn on the hazard lights, all lights blink except the front left side. However, when turn signals are used, the front left works right. Is there a separate bulb for the flashers?
I'm thinking it might just be a bulb out. Suggestions? This isn't that big of a deal...however I will need to fix this before inspection next year.
2. This next question is in two parts.
A) At night it seems that the only interior light is under the dash on the driver's side. Is there supposed to be one on the passenger side also? Maybe this is another bulb? But I can't find anywhere in the manual where it talks about replacing the passenger side interior bulb(s). Nor can I see one when I poke my head under the glove box.
B) What is the easiest way to disable the interior lights when the doors are off, so I don't drain the battery. I saw someone mentioned putting a switch between the fuse and light..that is something I'll most likely do in the future, but for now, I'm looking for the quick fix. I'm assuming just pulling a fuse? But which fuse (which cavity)?
3. Out of the 4 windsheild washer jets, only 3 are working. Checked under the hood and there doesn't seem to be a crimp. Maybe it's a clog? I'm sure you 4-wheelin types run into this often? Suggestions for cleaning?
4. Finally, I asked this in another post, but I'll reiterate. I plan on putting a sound bar in. I have read that there should be a wiring harness already in place for this? The stereo is aftermarket Pioneer single cd. Where would I look? I've poked my head under the glovebox but can't see anything. Do all sound bars require drilling? Even the ones from jeep?
I appreciate any and all help I can get!!
Thanks
Geoff[addsig]
Thanks
Geoff[addsig]
