What engine and intake are you reffering to on this GM TBI? do you have a 304 or a 360?I like the GM style throttle body injection systems because they don't stall on step asending or desending grades. Second best to an all out EFI conversion. :shades:
You have my attention. Is it possible to post out all the components and sources for this conversion?, maybe Dempsy could also be interested with this as this would be a better option. I myself has been contemplating on which upgrade i could do for my fuel delivery to possibly be more efficient. I appreciate your time. And Pics would also be great.My 72 cj5 had a 304. I had a carb on it, but the adapter plate is easy to make. And the wire harness n controller isn't hard. I converted my YJ to EFI but that was a kit with the speed sensor, manifold and all. :shades:
get new u-joints and a hi speed balance on the shaft. if the vibs persist, is your front shaft also true, if not and you accidentally left a hub locked, you'll feel it.
When you lifted, did you simply re-use your drive shaft?
if all else fails check your tires, make sure they are balanced.
