Ignition Modules!!!!! UGH
Okay guys, I need some quick help on this issue. I have an 80 CJ5 258 and I did the tfi upgrade. I am pretty sure I removed the resistor wire when I re-wired everthing. I bought the four (4) 8ohm 20 watt resistors from Radio Shack and I just need info on how to install them. Do I connect each one to each other like in a train? Do I install them close to the coil or close to the ignition module. Lastly, I believe they get connected inbetween the ignition module and the coil, on the positive terminal of the coil. Is that correct? Any help will be much appreciated.
