HELP for FOG LIGHT Wiring
adpeacock
I need help wiring fog lights into my XJ. I am unsure of what fuse they go into. Any help would be great. Thanks.
Are you trying to wire up factory fog lights, or a totally new aftermarket system?
The factory setup for the aux lamps uses the fuse #17 from the power distribution center(fuseBox). depending on what type of lamp your installing would be contingent on whether you need to run an external fuse or factory setup. i would not recommend you use the factory setup if you intend to install those high power spotlamps. it will fry your factory harness.
