JeepGirl247
I was installing a set of unsealed beams and StreetGlow H4 90w/100w bulbs this afternoon and have had nothing but problems with it. (NOTE-I purchased them used from a friend and he said the bulbs are fine). I've replaced the sealed beam headlights in my 88 XJ many times before, but the unsealed beams are a first. Here is what happened:
Once I installed the first headlight, the bulb would only burn after I used a stick to jiggle around the headlight wiring as I reached in from behind with the hood open. My other headlight (which was my stock sealed beam) was working fine and shining bright like usual. Then when I took it out and installed the second unsealed beam headlight, it worked but the other headlight bulb wasn't burning. It was just a mess! So, I jiggled the headlight wiring from behind again and got them both to burn together. The one bulb was dimmer than the other. I then put on the high beams, and the dim bulb had no high beam, but the other bulb did. Then when I switched back to the low beams, neither of the two bulbs worked.
So, I ended up putting my stock sealed beam headlights back in...they were giving me problems at first (i.e. the high beam wouldn't work on the passenger side), but now they are working just like normal.
Does anyone know what could be going on?
Thanks.
Thanks.
