They blink fast but I'm not
Worried about that my problem is that when I put the right blinker on both of the lights blink and when I put the left side on nothing happens at all
you will need a HD towing flasher, that will make the light blink correctly, fix that and see if the other issue is solved. there is only 2 wires per light from the jeep, can't be hard to figure out what your did wrong.
Yes there is a separate ground I bought a led flasher unit from genright but when I put that in none of the lights work I even emailed them for a wire diagram but heard no response
The lights back there are simple enough as far as the wires go. Could the plug for the lights be on the wrong way? Do the LEDs come with a harness to plug into the stock ones? The old tail lights were grounded with the bolts to the body right? The new one has a new ground installed?
The genright lights come with a plug with three wires that come off simple enought to hook up that's y idk ways wrong I used a test light found out wat wire was wat on the jeeps wire harness and the wires are labeled on the tail light as well idk if there's a bigger problem somewhere else that I'm missing
