Well, the Rear passenger side of the tub seams to sit lower than driver side, this was visually noticed but, you have to look really close to see it. Imagine if you will, you are comming off a rock and slam down on that wheel, it could ever so slightly, bend the housing up and forward. well, that would make that sit higher. My goodness, I have worked with this so long and dilegently, that I have completly drivin myself confused.
Jeep checked all the undercarrige and saif that everything was tight. Even said that if the tires didn't wobble on the old truck that a tight suspension "could" begin to wobble.
The Tub shows no sign of any shifting.
Other than the rear tire, measured from the frame to the mold line of the tire. Rear of the tires showing 1/2" more as if the Rear passenger tire is Toed-in there is nothing off.
Here is how I tested that. I measured from the frame to the center mold line of the tire on the Rear then on the front. 1/4 to 1/2" difference was noticed. I even rolled the Jeep forward to see if it was the Axle-shaft. Same Toe-in was noted. Nothing under the rear-end is adjustable.
I hope that the new tires will control,no, STOP the wobble.
Oh yeah, I STILL love my coils
