TwistedCU
Active member
I have a set of 2" coil spacers. Can I use them in place of the factory coild spring isolators to net a little less lift?
The front end sits noticeably lower than the rear. I got alot more lift from the rear end than I thought with the short AAL's and shackles. It looks like around 1.5" would bring the front up just right. If the stock isolators need to be in place, I'll order a smaller set, but I'd like to do it tomorrow.
