Coil spacer question
TwistedCU
I have a set of 2" coil spacers. Can I use them in place of the factory coild spring isolators to net a little less lift?
The front end sits noticeably lower than the rear. I got alot more lift from the rear end than I thought with the short AAL's and shackles. It looks like around 1.5" would bring the front up just right. If the stock isolators need to be in place, I'll order a smaller set, but I'd like to do it tomorrow.
Stock Isolators are .75" I don't see why it would hurt to remove them.
Yep, most of the spacer kits are actually 1 3/4". They say they are 2" if used in conjunction with the factory 1/4" insolators.
.75", .25" which one of you guys are right? I hope L33TJ33P is, 'cause that would work out perfectly!
This is the part where someone says they're .5" hehehe
Most 2" coil spacers are actually 1.75", and the stock isolators are .75". They are advertised at 2" because the manufacturers are retards and can't make it 2" or advertise the correct length. Nothing to do with the factory isolator.
And yes, you can use the 1.75" spacer without the factory coil isolator. Remember that they're all stackable so you can use several factory isolators to adjust the ride height.
