75/140 synthetic on the front and rear axles.
SPECIFICATIONS - FLUID CAPACITIES
DESCRIPTION
SPECIFICATION
FUEL TANK 19 U.S. Gallons (71.9 Liters)**** ENGINE OIL Engine Oil - with Filter - 2.4L 4.75 L (5.0 qts.) Engine Oil - with Filter - 4.0L 5.7 L (6.0 qts.) ENGINE COOLANT Cooling System - 2.4 L 8.5 L (9.0 qts.) Cooling System - 4.0 L 9.9 L (10.5 qts.) POWER STEERING SYSTEM Power steering fluid capacities are dependent on engine/chassis options as well as steering gear/cooler options. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these capacities may vary. Refer to 19, Steering for proper fill and bleed procedures. AUTOMATIC TRANSMISSION Service Fill - 42RLE 3.8 L (8.0 pts) Overhaul Fill - 42RLE 8.3 L (17.6 pts.)♦ ♦Dry fill capacity. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these figures may vary. TRANSFER CASE NV231 1.0 L (2.2 pts.) NV241 2.0 L (4.2 pts.) MANUAL TRANSMISSION NSG 370 Approximate dry fill or fill to bottom edge of the fill plug hole. 1.5 L (3.17 pts.) FRONT AXLE ± .03 L (1 oz.) 181 FBI (Model 30) 1.2 L (2.5 pts.) 216 RBI (Model 44) 1.89 L (4.0 pts.) REAR AXLE ± .03 L (1 oz.) 194 RBI (Model 35) 1.66 L (3.5 pts.)* 216 RBI (Model 44) 1.89 L (4.0 pts.)* * With Trac-lok add 118 ml (4.0 oz.) of Limited Slip Additive. ****Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure. At 60K, spark plugs needs to be replaced per maintainance schedule B.
