CJ OIL PAN SKIDPLATE?
The length of the antenna cable is not important, the different lengths are compensated for when you tune the antenna. As far as the ground, ideally what you want is a good ground plane, not just simply a good contact to ground. This is why antennas will perform better when centered on a roof compared to mounted to a bumper for instance. The amount of grounded metal surrounding the base of the antenna will directly relate to how well it will tune, but as I wrote before, so long as you can get the SWR's to an acceptable range, it would perform plenty well enough for trail riding. As far as the lenght of the antenna, the ideal length is 102". This is, of course, very impracticle and that is why CB antennas use a wound coil in the mast or at the base. The higher the mast reaches above the highest solid metal part of your Jeep, the better it will tune. Amplifiers are illegal, and quite annoying to anybody near you using a TV, radio, etc. It's a law that is nearly impossible to enforce though. You really don't need one if you setup and tune it properly!
Sorry for writing this book. I haven't even thought of CB's in a few years, and it all just came pouring out! Funny thing is I never even owned one, but selling and installing them for 4 years I learned alot about them!
