Can't find a passenger steering knuckle
All TJ D30 knuckles will be the same. why do you need a knuckle? are you upgrading? if so the D30 from the WJ is an upgrade for brakes as well as incorporates provisions for a Hi-stear arm.
My current knuckle has grooves worn into it from the brake pads, so I was just going to replace it with stock stuff.
What's involved in the WJ upgrade? New knuckles & calipers? I'm assuming I'd need tie rods, and a draglink as well. I've never heard of that upgrade.
http://www.jeepz.com/forum/cj-yj-tj-jk/29842-wrangler-brake-problems-worn-steering-knuckle.html
there is some work involved, and some welding. you also have to re-drill the rotors. not super hard stuff though.
My new brake pads did include some clips to help with the grooves. I'm going to install them tonight (weather permitting)
