77 CJ-7
When I step on the brake the radio stops working. When I keep the foot on the brake the radio comes back on so the actual cut off time is only a second or two. Lift the pedal, then press it again, the radio drops out.
Seems like a power draw issue related to the brake lights. Other electrical changes (blinkers, headlights, etc) don't cause the problem. The horn does cause it but it's wired odd so I'm not sure a great diagnostic aid. This of course used to work just fine so I'm not sure what shook loose or changed to cause the issue.
I hooked up a multimeter and the voltage draw seems pretty constant and the amp draw doesn't seem to change. I admit to not being an multimeter expert so I easily could have missed something.
Any ideas on what to look for?
