My left blinker is staying lit on the dash. Left blinker outside will not work. Right side works entirely. The blinker assembly inside the steering column is new. I don't think it is the blinker on the fuse block either. Any ideas???
Well, I just tried a new bulb and an extra flasher. Didnt solve it. This sucks. The only light that is dim outside is the driver turn/park light on fender. But even a new bulb was dim.
My cherokee had the same problem once, and what had happened was the grounding prong on the sockets had broken off. So without a ground, the power would back feed through the indicator lights in the dash.
