I started to disasemble my 79 CJ7 to replace the dead 304 with a 351W/T18 combination and noticed that the frame appears to be tweaked. I'm trying to figure out if it really is or if it is supposed to be that way. If I stand at a distance it appears that right in front of the firewall the frame bends to the passenger side. The crankshaft from the motor does not line up with the center mount for the radiator support, The outside of the rear passenger side tire stops almost deadcenter of the front passenger side tire. The outside of the rear drivers side tire is even with the outside of the front driverside tire. to me that says Bent frame, However when I get close there are no signs of the frame bending. None of the welds are broken, there aren't any stress cracks in the undercoating, it uses the double C channel frame construction and where the 2 pieces overlap the weld lines are still in tact if it was truly bent I figure the weld or something should have given to allow the 2 pieces to bend. Both of the frame rails at a distance appear run parallel to each other over the entire course so the bend would have to be at the same spot on both rails. am I being fooled by an optical illusion?
