82CJ7JEEP
Well after 3 months of slowly playing with the jeep, I am down to that last few items to correct/make better.
1. Where does/is the timing pointer supposed to be located? My haynes manual shows a location but the pic does not match the bolt locations on my engine? (I have not found a way to access/view the block casting numbers to determine actual year) If it will help I will take pics and post.
I have read that the timing is supposed to be 8-10 deg btdc. That I can handle.
2. Without dropping the transmission/transfer case skid plate is there a way to determine trans type? I believe it is stock transmission with an adapter housing for the 360. (4 speed, manual) it is attached to a Dana 300 transfer case.
Thanks for any and all information you can share.
