I have a set of 15x10 steel wheels off of my TJ, and I was wandering if anyone has run them or if they will fit alright? I am planing on lifting it 3-3.5" and it would save me some money if i can use them.
I've never seen a 10 inch wide wheel on a KJ body liberty. I would think that it would have serious issues with rubbing on turns unless you compensate that with the offset of the wheels. This in turn will sacrifice the longevity of the wheel bearings and suspension and steering components. A friend of mine whom i installed a 4 inch lift kit on his KJ retained his factory aluminum wheels and had a set of 33 inch BFG all terrain tires installed. It rubs on a full turn all the time. Just thought i'd share that with you.
