Hi guys
I'm back. Forgot I was a member here and I was deleted. I have spent alot of time learning about car mechanics and everything has been good so far.
Need some help this time
94 2.5L 150k 5 speed
At cold start up engine revs to about 1800 rpms then goes down to about 750 ish
I go in gear and get moving and suddenly it hesitates a few times then clears up. Second is worse sometimes if I don't get the hesitation in first. So I drive it and it runs good. I can hit 4k+ rpms in second. I can push the clutch in and floor it to the reddline. Safely of course, I just wanted to see if it could
So then I'm at 180 degrees or less and I turn it off. Turn on high idle for a few seconds and more spit and sputtering.
Huh. Drives me crazy.
Here's what I've done so far
Plugs
Wires
Cap
Fuel filter
Air filter
Tps
Map sensor
Cleaned the tb and new gasket
Tightened valve Cover bolts
Changed the stat to a 180 because the old one was sticking. It was doing the same problem with the 195 stat
Techron chevron injector cleaner
Brand new flow master two days ago to replace rotted muffler
I sprayed all around the intake and all the vacuum lines for leaks and no change in motor sound.
I'm at a point where it's going to take some know how to figure this out
List of possibles
Idle air control is bad completely
O2 sensor?
fuel pump?
Catalytic conveyor?
Possible timing?
Problem is I don't know enough to say which part would make this so intermittent. I can read ideas all say but I need to broaden this more
This just starting happening in November. I drive it daily.
Can we do some brainstorming?
Plugs
Wires
Cap
Fuel filter
Air filter
Tps
Map sensor
List of possibles
O2 sensor?
fuel pump?
Catalytic conveyor?
Possible timing?
