i had to redo some of the wiring on my 88yj and got the wiring problem fixed but know i cant get it to fire and im not getting a spark. can somene point me in the right direction to solve this problem?
Check the power and ground circuits relevant to the ignition. Re-trace the wirings you worked on. If you did a cut and splice on the harness, make sure that you got the replacement splices in the correct order. Sometimes, a wire will have a splice to another circuit to feed another component.
