Wipers and Fluid
stretch51
My 2000 Cherokee is being used by my daughter at college. she just called and says wipers "won't work and fluid doesn't work" - were working fine in the morning. I don't think I should have lost a wiper motor and pump simultaneously? Anyone know where the fusebox is located(the manual is vague)and she is an hour away. Also-anyone have similar problem?jjackson@mn.rr.com[addsig]
1053751
if both died at the same time... i'd say it is a fuse. fusebox on that jeep is accessed either under the dash on the drivers side, or if you open up the passengers' door... they'll be on the side of the dashboard under a panel...[addsig]
