Hello All. I have a 2010 Unlimited Rubicon and for the life of me, I cannot find the location of the turn signal flasher. I have taken off the plastic shroud on the steering column and found nothing. I hate to go by sounds, but the "click" seems to come from the top of the dashboard. I sure hope I don't have to pull the dashboard apart just to swap the flasher! I am trying to swap out the old light bulbs out for LED 3157's that I purchased on the web. The new bulbs work fine (and bright), but the flasher thinks a bulb is burned out due to the low current draw. Hence, it flashes at a rapid rate. If I can find the blasted flasher, then I can swap in an electronic flasher that will support the low current. Any ideas are welcome and I thank you in advance for your help.
