When is drive angle on a lift too much for stock parts?
1047664
dont worry about drivline vibs until you lift over 5 inchs.. lower your transfer case and contact 4 wheel parts or your local procomp dealer and get a set of axle shims.. put them between your spring and axle perch.. this moves the angle of the pinoin up more.. so your drive shaft is straighter.. also change your u-joints.. they wear in a pattern.. will get some spooky vibs from those..cheers
