Front tow hooks on a YJ
Ok Ok Ok FINALLY a TJ question. WOOHOO!!!!
31's will fit GREAT under your Stock TJ. As you stated you will prolly not get Swaybar Disconnects so you are fine with 31X10.50. Especially with the Crager 15" Rims. Those rims come with a 3.75 backspacing and you are set.
The lift is not needed but if you want a lift I will suggest http://www.rubiconexpress.com Budget Boost.
There are other Tires out there that will be good for you. I will suggest you stick to All-Terrians since you will be doing little off-roading. These will give you many more miles on the road but still give you some good traction in the Dirt.
The BFGs will not work on the Cragar Streetlocks but there are many other A/Ts that will accomodate you. The Cragar Street-locks look like they have a Really wide outer lip. This protects your Beads.
They do have MT Baja Radials that aren't "Bias Ply" but again these will never last you as long as an A/T.
:::Edit:::
P.S. Check out my Pics in the Readers Rides section, listed under L33TJ33P That is what you will look like with a 2" lift + 31X10.50X15 on the Cragar Street-Locks. Hope this helps.
:::Edit:::
