LukeBurl22
I'm looking for a light 35" tire. I'm going with a lighter tire because I'm not looking to regear my 07 JK
69jeepcj said:With one revolution, a larger tire travels a further distance than a smaller tire. This is why the gears ratio changes, not weight.
LukeBurl22 said:But I know the BFG KR2s run small so the actual height would be about 33.5". The tires I have now measure 31". Would it be that much of a difference where it would hurt me?
Weight has a lot to do with it. More mass takes more power to get moving. If you regear a Jeep to compensate for larger tires only, and return the Jeep to the same final ratio as when stock, you will have lost some performance to the added weight of the larger tires. This is why it's best to always regear a little lower than what the charts and equations recommend.With one whole rotation, a larger tire travels a further distance than a smaller tire. This is why the gears ratio changes, not weight.
Bounty__Hunter said:Right. The 35" tires are gonna really kill performance if you have the anemic '07-'11 v6.
Bounty__Hunter said:You'll feel it, especially with that minivan motor. Why not invest in gears instead of tires?
LukeBurl22 said:I'm just trying to find the cheapest route
LukeBurl22 said:But around how much would it cost me
