what do you think of this
bluejeeper
Hey guys hers what I did to the old yj just put her back together after a long project. Cut out all the rust and welded in new sheet metal, body work and then paint. Painted por 15 on the under side and the in side of the tub. New exhaust, new radiator, new plug/wires, distributor, alternator, battery. probably missing some others. New brakes all around with new hard lines and stainless steel break lines. Suspension lift 3” rough country and a 1”body lift.
Know hers the question will 33’s fit with out trimming the fenders? And I only have high beams that work I have no low beams. What do you all think? Will try to get some pic for you all thanks …
33" will be tight, depends on the manufacturer and condition of the spring kit. You'll likely get a small amount of tire rub that you can live with.
Swapping in TJ flares will give you a lot more room for tires, and would even allow you to run 33" tires without the body lift.
