Weird problem...
tjsurf151
Wondering if anyone could help me on this, jeep idles incredibly rough until warmed up and if I drive it will bog in and out, already replaced plugs and coils...
Any check engine light
Upstream O2 sensor could be going bad, sometimes they wont trip the check engine light
Sent from my DROID 2 Global
Sounds like a vacuum leak. Take a can of Carb cleaner and spray around the intake where it meets the head and around the carb/ t-body base. Inspect the vac lines closely. TYpically a leaking intake manifold gasket will make it run rough untill the engine heats up and the metal part expand which seals off the leak.
